Can't get over the speed of 6.5 on the screen, but the boat obviously goes over this speed. Battery was changed. Have you seen this issue? Speed on screen stops at 6.5, but seems to go faster. Can't get the waive either.
Moving this to the Tech Discussion section since it doesn't meet the GUIDELINES FOR POSTING IN THE DIY SECTION.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Not much to go on here, but if I made an educated guess, I would say your boat is having issue with the CanBus communications that ties all the electronics together. That would prevent the GPS speed data from getting to the screen and would also prevent control of NSS such that you wouldn't get a surf wave. I would assume a 2021 is under warranty, so seems like you need to get it into a dealer.
