2007 super air nautique 220 TE start button does nothing.
  • Jrod77
    • May 2022
    • 15
    • New Braunfels, TX
    • 2007 Super Air Nautique 220 TE
    pressing start for the 3rd time doesn't do anything
  • Jrod77
    • May 2022
    • 15
    • New Braunfels, TX
    I was out on the lake a few days ago and had no issues. I stopped and started the boat a few times with no issues. The last time I pulled a tube for about 30 minutes I stopped and went to restart and nothing happened on the 3rd time I pressed start to turn the engine over. Please help
    • swatguy
      • 1669
      • Midwest/ Northern IL
      • 2008 SANTE 210
      Have you tried “resetting the system “ by flipping your batter selector to completely off for few minutes or disconnecting negative terminals if you don’t have a dual switch.
      • Jrod77
        • May 2022
        • 15
        • New Braunfels, TX
        swatguy, I was able to figure it out. Took the shroud off the engine block and replaced all the fuses in the Breaker Box. It appears that the Starter Ignition relay fuse wasn't sat in the seat all the way. Fired right up, so I replaced all the fuses and got backups if it ever happens again. Thanks for the reply.
        • srock
          • Oct 2008
          • 1161
          Always remember that a common cause may be the kill switch, the throttle position not in neutral, and on a 2007 the bildge pump toggle switch.
