Transmission Coupler Clearance Problem After 80A Swap
  • GBoucher
    • Jul 2020
    • 16
    • Nashville, TN
    I have just swapped out the old PCM 40A transmission for a new 80A in my 1997 Ski Nautique. After installing the transmission, I have now run into an issue while trying to do a shaft alignment.
    The shaft extends beyond the mating surface of the coupler, and butts up against the nut on the back of the transmission; this does not allow the coupler to actually contact the transmission's side of the coupler. On the old 40A, the transmission nut was set deeper, which meant there were not any clearance issues.
    Is my shaft coupler incorrectly installed too far onto the shaft? Should I remove the coupler and reinstall so that the shaft does not protrude past the mating surface? If so, is it OK to attach the coupler bolts and just tighten them until the coupler pops off, using the shaft itself as the spacer? Is there any reason that I need to replace the coupler itself?
    Here is the shaft sticking out past the coupler:
    This is as close as the couplers can get currently:
    Here is the old 40A transmission, you can see how much more clearance there is with the nut:
  • jpwhit
    • Aug 2016
    • 526
    • Cary, NC
    Yes, you need to reposition the coupler on the shaft to get the right clearance for it to work with the 80A. I doubt the coupler was originally installed like that, I suspect it slide in coupler over the life of the boat.
    • GBoucher
      • Jul 2020
      • 16
      • Nashville, TN
      Ok got it, thanks for the response. I didn't think it would have been possible for the coupling to just slide further back than it was supposed to, I figured it would have been limited by the keyway. I'll try to pull it off and reposition. Is there a recommended distance from the end of the shaft it needs to be?
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        No, but keep in mind that this is going to push the prop back a bit. Probably not enough to matter, but keep an eye on that as well.
        -Charles
        • 625262
          • Oct 2024
          • 3
          • Saint Charles, MO
          • Bluewater 51' 1984
          Captains
          I am interested in buying a couple of PCM 40A / Ratio: 1.23 cores......
          Capt Alan Deutschmann, Pres.
          Midwest Marine Services
          cell: 314.581.0514
