2020 G23, zz6, hot water shower
  • Jericko
    • Sep 2024
    • 1
    • Courtenay, British Columbia
    • 2020 g23
    Any one have any luck plumbing a shower setup on zz6, curious about routing with it being a closed cooled unit, live far from the dealer and would rather mess it up myself first haha, anyways, cheers!
  • Jonny Quest
    • Aug 2014
    • 380
    I've asked the same question before.......no viable responses. I've got the ZR6 with closed (fresh-water) cooling on my boat and I really would love a hot shower. The only thing I can think of is to make the hot water source the output from the exhaust manifold cooling water. Then you can add a "cold" source from the raw water side or just after the impeller. I haven't tried it -- just thought about it, but it should work. I don't know what the temp is of the water coming off the exhaust manifolds, but with a ball valve on the cold input, you should be able to regulate the final temp to a reasonable level.
    Just the ravings of a delusional mind...
    JQ
    • Scooter G
      • Jan 2022
      • 1320
      • On a Lake in Idaho
      • 2022 G23 ZZ8
      I'm all in here, I'll let one of you go 1st
