rear cooler on my G21 separated
  • jarrett.hale
    • Sep 2024
    • 1
    • cl
    The rear cooler on my G21 came separated from being overweighted with cold beverages and rough water. It appears to be adhered with a hard epoxy. Does anyone know what Nautique uses? The other issue, it does not seem like I will be able to remove the loose cooler to sand and prep for glue based on what I am seeing. Does anyone know a trick for removing the cooler without doing some major removal of other components? Any info or guidance would be helpful and greatly appreciated!
