Hi All,
1997 Sport - I'm on my 2nd cable in 6 years. First one lasted 150 hrs and 3 years. Second one is starting to get harder to steer. 150 hrs and 3 years also.
I'm curious if there are multiple manufacturers of this cable, or different types to try. I have the "newer" helm with a tilt wheel and the "rectangular" shaped end cap to the rack.
The last two cables were from NP, 90590. Customer service, as always, has been amazing. They warrantied the first failure. I don't anticipate the same on the 2nd. I'd just like to buy something that will last longer as I really hate the job of changing out the cable!
I've seen some reading on "sealed cables" primarily for salt water use I assume? Is that an option?
My boat is used in fresh water, covered, on a covered lift. And garage kept with a cover in the winter. It does take the occasional surf wave over the bow (1-2x per year), but I wouldn't say it ever sits with water in the bilge, or nothing significant for sure. (I only have a drain by the engine, and my lift sits a bit "stern heavy" so it isn't level enough to drain when on the lift).
Thanks in advance! If I'm stuck doing it every 2-3 years, so be it. Just not how I want to spend my time if I can help it.
