Bottom line: Is there any possible reason a transmission fluid leak apparently coming from the bellhousing would be anything other than a bad front main seal on the transmission?
Full details:
At the beginning of the season, I launched my 1997 Ski Nautique and had no transmission engagement (PCM 40A). I checked the fluid level and it was completely dry. It apparently leaked out in storage after my fluid change during winterizing. I pulled the transmission, replaced the front main seal, re-installed, and filled with fluid. Everything seemed great, boat ran fine, but the next morning there was more transmission fluid in the bilge.
I decided to completely replace the transmission and upgrade to the 80A kit, including a new damper plate, transmission cooler, and hoses. Through a series of events (like a seized coupler and propeller to the driveshaft), I also replaced the driveshaft, coupler, cutlass bearings, shaft packing and rudder packing. I also made sure to get an excellent engine alignment to within 0.0015".
I finally got the boat back in the water to test with all the new components; again, everything seems great on the test drive. The next morning, however, there is absolutely no fluid on the dipstick. It's hard to tell where exactly the leak is coming from, but there is fluid on the exterior bottom of the transmission as well as the bellhousing area where it mates to the transmission. I assume that the bellhousing is the source, since it's 'upstream' of the transmission.
Everything I've read suggests that a leak in the bellhousing area means it's the front seal; what are the chances the main seal is bad on a brand new transmission? Is there anything else it could be, before I tear apart my engine bay for a third time? In both the old trans and the new, it appears to be a very slow leak when the boat is trailered, and a much faster one if it has been recently driven. Is it just coincidence that I have almost the exact same symptoms on the old transmission and the new? What am I missing?
I've been so frustrated by this, I'm hoping someone can give me some insight.
I took this picture of the new 80A before installation. Does anything look out of place?
Full details:
