Hello, I recently bought a 1992 Supra Impulse with Ford PCM pro-tec. The boat has low hours and in good shape but the carb needed a rebuild, which I had done and tested. I want to check / set initial timing after reinstalling the carb but not sure how to do it. The PCM manual says the only adjustment needed on these is setting initial timing, so I presume it can be done. Is there a small clamp on or under the interrupter / "puck" that can be loosened to rotate it like a distributor? Any help is very much appreciated. I searched for this topic and didn't find it. thanks for any info! Doug from NH
- Aug 2014
- 381
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
Static timing is 10 degrees BTDC, 18 degrees BTDC at 700 rpm. You have to disconnect the knock sensor prior to checking / setting timing.
JQLast edited by Jonny Quest; 01-18-2025, 11:07 PM.
