Hello, I recently bought a 1992 Supra Impulse with Ford PCM pro-tec. The boat has low hours and in good shape but the carb needed a rebuild, which I had done and tested. I want to check / set initial timing after reinstalling the carb but not sure how to do it. The PCM manual says the only adjustment needed on these is setting initial timing, so I presume it can be done. Is there a small clamp on or under the interrupter / "puck" that can be loosened to rotate it like a distributor? Any help is very much appreciated. I searched for this topic and didn't find it. thanks for any info! Doug from NH
- Aug 2014
- 378
- Salt Lake City, Utah via Texas
- 2003 Ski Nautique 206 Limited with ZR6 Engine
Staic timing is 10 dgrees btc, 18 degree's at 700 rpm. You have to disconnect the knock sensor to time as the computer changes the timing if the throttle isn't moved in a set amount of time.
JQLast edited by Jonny Quest; 10 hours ago.
