2020 Nautique G23 Paragon
  • Mikesgood
    • Nov 2024
    • 5
    • Lake Washington
    • Seattle, WA
    • Nautique Paragon G23 2020
    I am changing the oil on my G23 Pargon with a ZZ8 turbo charged engine. The dealer gave me Amsoil 10W-40 oil. I noticed online that it recommends 5w-30 Dexos Gen 2 motor oil. What should I use?
    Also I am changing the Transmission fluid and V-drive lubricant. They sold me ATF MD3. Is this correct and how much should I add?
    The V-drive / gear oil is Pleasurecraft. How much should I add?
  • BasaltRMK
    • Apr 2020
    • 284
    • Basalt, CO
    • 2024 SAN G23 2020 SAN G21 (Sold) 2018 SAN G21 (Sold) 2015 Tigé R20 (sold) 1972 MFG Gypsy-15 Tri-hull (sold)
    Congrats on the new boat! One clarification, the ZZ8 is supercharged, not turbo charged. I have a 2024 G23 with the ZZ8s, and the PCM manual specifies 0W-40 for the SC. I'd recommend following the PCM guidance on the oil weight. I use Mobil 1 0W-40 supercar formula. I talked with PCM and they also stated that the Mobil 1 0W-40 European car formula or ESP formula would be acceptable as well. Best of luck!
    - bob
    • Mikesgood
      • Nov 2024
      • 5
      • Lake Washington
      • Seattle, WA
      I have a 2020 Nautique G23 Paragon with zz8 supercharged engine. I am trying to change out the impeller. I noticed that the 2 hoses going to the raw water pump are coming from the anti-freeze storage. When I remove the bolts from raw water pump is anti-freeze going to come out?
      • Mikesgood
        • Nov 2024
        • 5
        • Lake Washington
        • Seattle, WA
        I have a 2020 Nautique G23 Paragon. I am changing the transmission fluid. The dealer gave me ATF MD-3 Chevron fluid. Is this correct? I have the ZZ8 supercharged engine.
        Also I am changing the V-drive lubricant. The dealer gave me P/N R190251 Powerplus V-drive Lubricant. Is this the correct lubricant?
