oil pan replacement on a 93 ski
  • peterholman
    • Mar 2006
    • 5
    Has anyone ever tried to replace an oil pan without removing the engine on a 93 nautique or similar year? I have a pin hole leak which I cannot stop on the bottom of the pan. Its all mirror and flashlight work.It looks like it might be possible.
  • boatech
    • Aug 2006
    • 247
    RE: oil pan replacement on a 93 ski
    not worth it. just pull the motor. i can pull the motor in less than 30 minutes but ive done a bunch of them. its not hard to do on a direct drive. if you have some mechanic skills and some tools should take you couple of hrs tops to pull. trying to replace the pn without pulling the engine is not something i would recomend at all.
    • richard
      • Feb 2005
      • 406
      • HK
      My experience is you must pull the engine out for replace the oil pan,
      and fighting the rust engine mounts,and then alligment for prop shaft; negotiate an acceptabe $/experience mechanic do it for you sounds the best way, if you like challenge and expend min.$ and have time,try youself, not impossible.
