93 oil pan replacement
  • wakextrem
    • Sep 2005
    • 15
    • florida
    does anyone know were i can buy a replacement oil pan for a 93 ski
    it has a 351 dd
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: 93 oil pan replacement
    SKIDIM Discount Inboard Marine. Or Try any boatyard to see if they have a seized motor that has a good pan
    Nautiqueless in San Diego
    • wakextrem
      • Sep 2005
      • 15
      • florida
      skidim only has a bent used one and they want 300 for it i was also wondering if i could use the one i found on ebay its off a 351 bronco
      • TRBenj
        • 1681
        • NWCT
        Im not sure how many different types of 351w oil pans there are, but Im sure the PCM version is the same as one of the automotive applications. Why dont you call PCM or SkiDIM and see if they can give you the Ford part number, then cross reference it to find out what type of vehicle(s) it came on? Then you can search for a good used one at a junkyard.
        1990 Ski Nautique
        NWCT
