Removing old stickers/decals
  • licka77
    • Dec 2006
    • 5
    Whats the best way to remove stickers or decals?
  • NigelC
    • 161
    • UK
    • 2010 Ski Nautique 200 Open Bow Team Edition
    RE: Removing old stickers/decals
    I removed mine using hot air from a hair dryer to soften the decal as you gently peel it off.
    Depending on where you are located at this time of year, I am not too sure if this would give you enough heat if you attempt this outside in a cold environment.
    2010 Ski Nautique 200 Team Edition Open Bow, Radar Strada
    Dealer: http://www.midlandsnautique.co.uk
    • ryanandrews
      • 233
      • chippewa lake ohio
      buy an eraser wheel for your drill.........they work.
      • redelf75
        • Sep 2003
        • 767
        • NYC
        Does anyone have any experience with side graphics on a 3 year old boat? I'm thinking of going naked and have concerns about ghosting. Thanks.
        • MHayes
          • Aug 2004
          • 830
          • Roswell, GA
          If you have some ghosting I'm sure that it can be easily removed with some light wetsanding or even with a good buffing compund and a buffer.
          2001 Air Nautique
          • 06210rider
            • Jul 2006
            • 51
            What color are your hullsides. High pigmentation colors like reds, blues, and blacks will have a halo or ghosting effect that is much deeper than lighter colors like yellow green orange and the tans. It also depends on how often you waxed your boat and if it was stored out in the sun. I would not recomend an eraser wheel because of the likelyhood of burning your gelcoat. The best was is def. with heat from a heat gun or using decal removing chemicals.
            • jhiestand
              • 779
              • Columbus, Ohio
              • 08 Super Air 210
              I'm in a similar boat (pun intended!) with the dealer delivery checklist decal under my engine hatch. All the other safety decals came off easily with a hair dryer, but this one is a gnarly, stubborn thing and I've tried all sorts of methods. Now it's a 1/2 torn up mess!
              Are the eraser wheels for drills available most anywhere? Anyone else had luck with them? I've tried multiple chemicals and heat hasn't worked.
              '08 Super Air Nautique 210
              • geoffc210
                • Jan 2006
                • 47
                I would be interested too if you can find anything for that one decal. I can't get that thing off of my boat either. I tried one corner and determined it was too tough and left it.
                • efox
                  • 237
                  • Lawrenceburg,In
                  Try "Goo-be-gone". you can buy it at Home Depot or similar. Apply it to a sponge or rag and wipe it over the decal and leave it there for a while. They will be easy to peel and then it will clean up with soap and water and is biodegradable. Safe on fiberglass and gel. I used it to remove the registration stickers which are normally tough to get off.
                  Eric Fox
                  • ryanandrews
                    • 233
                    the eraser wheels will not burn your paint or gelcoat.........if used in a cordless or corded drill it is impossible......i run mine with an air compressor......works very much better and faster. you can pick them up from a paint/auto body shop....maybe even autozone.........mine is from snap on.......most major tool company sells the things.......cost is around 30 bucks.very good investment!!.good luck
                    • licka77
                      • Dec 2006
                      • 5
                      Im from Australia- I ended up using a product called Wax and Grease Remover.
                      This product is absolute gold. I had a heap of stickers to get off- 2 which were particular stubbon. 1 of which wouldnt come off with the hair dryer. But A couple of Soaks with this stuff, and I was able to remove.
                      I have heard of this product called Presol before.
                      Thanks for everyones help.
                      • Brownie
                        • Jun 2004
                        • 87
                        • Nowra/Taree NSW, Australia
                        what boat did you get Licka77
                        • ag4ever
                          • 1180
                          Re: RE: Removing old stickers/decals
                          Originally posted by efox
                          Try "Goo-be-gone".
                          FYI, it is called Goo-Gone. I worked at an electronics repair facility while in College, and we used the stuff to clean all kinds of parts that were gunked up by auto dealer's parts department. A few of us called it Goo-B-Gone, and some kept razzing us since that was not the name. After that we started writing in the B between the two words and started giving them a hard time.
                          A smart entrapanuer could start a new company and call it Goo-B-Gone, and everybody would think they were the original.
                          • Fonseca
                            • Apr 2006
                            • 35
                            • Portugal - Castelo de Bode
                            RE: Re: RE: Removing old stickers/decals
                            Ok to remove and what about to put the new ones?
                            A friend told me that the best way is spraying the support with water before place the sticker. That should allow moving the sticker to his right place.
                            Does anyone have tried this method?
                            • Hollywood
                              • Sep 2003
                              • 1930
                              • WIIL
                              Something else that might work, though I really love the smell of Goo Gone
