Perfect Pass
  • pj
    • Oct 2003
    • 323
    • Rochester, MN
    • 1991 SN 1996 SN
    The magnets do not adjust the RPMs. They only provide timing for the system.
    Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
    • skiinxs
      • 374
      • St. Louis
      • 2019 Ski Nautique 6.2 arriving soon
      In a sense, the magnets do adjust the rpm's. When the system reads the entrance gates, a percentage of the skier value is added to the baseline rpm. If the system reads the entrance gates but doesn't read the three ball magnet, it will drop the skier value out before the end of the course. To operate properly you must have magnets on at least the entrance gates and 3 ball or use the hand timing switch to manually trigger. Without this the skier value will never be added and your times will be slow. The only way around this is to bump your baselines and run without a skier value. If you bump them the correct amount you can get good times, but you will be killing your skier through the gates, since you will essentially be entering the course 1/2 to 3/4 mph hot and letting the skier pull the speed down. Not too pleasant at the gates doing this.
      Dave
      16 other Ski Nautiques
      3 MasterCrafts
      18 Ski Supreme's
      1 SlickCraft Squirt Boat
      • pj
        • Oct 2003
        • 323
        • Rochester, MN
        • 1991 SN 1996 SN
        Thanks for the clarification, Dave. I forgot about that. Man, winter isn't good for my ski knowledge.
        • MARK-S
          • 764
          • SE MINN
          • 1978 Ski Tique 1996 196 2001, 2002, 2003, 2004,2005,2006,2007,2008 196s Best boats made
          PJ,
          We are under 2 weeks for open water. maybe by monday if we get those 60s.
          Life long Nautique guy
          Will ski anytime.
          \"SON WATERSPORTS ROCKS\"
          • pj
            • Oct 2003
            • 323
            • Rochester, MN
            • 1991 SN 1996 SN
            SAWEET!! We have open water on the main channel over here. Going to try and hit it this week some time. I'm dying to start chasing those buoys though.
            • skijones
              • Mar 2005
              • 235
              • COLUMBUS OH
              • 1985 2001 1999 Snob
              #21
              Thanks Todda. Hopefully I will be on the water soon, just melting the ice here in Ohio
              • MARK-S
                • 764
                • SE MINN
                #22
                let me know if you go. I may be in DFW this weekend, but I would love some free skiing to start the year off.
                Will ski anytime.
