Slight vibration on GT40 engine
  • dwsa
    • Sep 2005
    • 134
    Idles fine at 650, as revs increase to about 750 the fuel cell shakes quite violently on its bracket, slightly higher revs it's fine. Top end speed is fine, no other problems. Am I worrying over nothing?? Thanks.
  • ryanandrews
    • 233
    • chippewa lake ohio
    RE: Slight vibration on GT40 engine
    crank itupto 4500-4800 rpm........make the passengers shake!.........loose bolts?.........engine trsnny mounts loose?............
    • SGY
      • 990
      Check your plugs, plug wires, cap and rotor. I had a similar problem on my Excaliber motor. Turned out it was the cap and rotor. You might have a similar "mis".
      • dwsa
        • Sep 2005
        • 134
        Fixed, it was the harmonic balancer / damper.
        • harddock
          • Apr 2008
          • 292
          • toontown E-9
          Re: RE: Slight vibration on GT40 engine
          what did you do/ tighten? replacce?
          • SGY
            • 990
            RE: Re: RE: Slight vibration on GT40 engine
            Dwsa, give us more info on this. What did you do to fix the HB/damper?
