Hard Steering to right around island
  • jncbabcock
    • Feb 2007
    • 5
    • Granada Hills, CA
    I am having to grip the steering wheel very hard with two hand's to steer around the ski island to the right.
    Any solutions to this problem?
    Jason
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Hard Steering to right around island
    Jason It may be the torque of the engine. With the engine off and at the dock try moving the wheel in both directions, Is it the same in botjh directions? If so it is the torque of the engine that ,mmakes it hard to steer to the right. I beleive there is an adjustmen you can make if the boat has the tunable rudder. If it is hard in one direction while sitting at the dock it is the rudder cable. They run around $250.
    Nautiqueless in San Diego
    • G-man
      • Jun 2004
      • 428
      • Allen, Texas
      How old is the steering cable? You may just need to pull the rudder, grease it up, grease the cable and put it all back together
      Current
      2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
      Previous Fleet
      2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
      2004 Ski Nautique 206 LE Red - Black - Silver Cloud
      1993 Mastercraft Stars & Stripes 190 Red
      • jncbabcock
        • Feb 2007
        • 5
        • Granada Hills, CA
        Any tips to pulling the rudder? I have a 99 Ski Nautique with a tunable rudder.
        • Rick
          • Mar 2004
          • 1250
          • San Diego, Ca
          It's easy.... Just pull the back seat out (you will probably have to pull the driver side cooming pad to get it out) then undo the shield for the gas filler and vent. Then remove the engine cover and floor board . Then disconnect the filler and fuel lines (make sure you mark them in and return) and remove the gas tank . Uh maybe its not so easy... I've done it several times on my 2000SN and it takes about 3 hours. If you are going to do it I suggest you have a line on a steering cable. That way if it is the cable you can replace it while everything is apart. Also while you have it apart you should repack the rudder. Search for the post on this forum. You need 1/4" packing I like the teflon impregnated flax. Make sure you support the bottom of the rudder as it will fall out after you take the arm off and loosen the packing. Good luck
          • dan1495
            • Jan 2007
            • 3
            I have done it several times on my 99 Nautique without pulling the gas tank. It takes a long extension and a little patience, but it is not that hard. Also, don't try to reuse the old safety wire - buy a roll of new wire.It makes a huge difference in steering effort on right hand turns.
            • jncbabcock
              • Feb 2007
              • 5
              • Granada Hills, CA
              Thank You
