When to change transmission fluid
  • Ponyh8r
    • Mar 2006
    • 9
    I have an 06' 210 w/ the PCM 330hp engine. I was looking at the service interval and it says that changing the transmission fluid once a year is optional. My boat has about 100 hours on it and the fluid was changed at the 25 hour service. Does it need to be changed again? I haven't used the boat since Nov. but it is warm enough again to start riding.
  • MNSuperAir
    • Sep 2005
    • 591
    • St Paul
    • 2016 SAN 210
    RE: When to change transmission fluid
    I change mine every fall. It is pretty easy to do too.
    2016 SAN 210
    2006 SANTE sold
    2001 SAN - sold
    1991 Sport Nautique - sold
    • Onthewater
      • 695
      • Near the cheddar curtain
      Ditto, end of the season or 100 hours, which ever comes first. Then do it again before layup.
      I don\'t care.
      • ffmedic74
        • 835
        • Lexington, KY
        Just get a manual hand vacuum pump that hold about 30-40cc. Suck out the fluid through the transmission fill tube. Repeat until you cannot suck up any more and and replace with the same amount of fluid.
        • bscott
          • 188
          • Bolingbrook, IL
          ... or get a drill pump. Inexpensive and much faster than hand vacuum pump.
          • Quinner
            • 2245
            • Correct Crafts
            I also change mine every fall + mid season if more than 50 hrs at that point.
            Bought a suck-up vacuum pump from DIM and it is the best of any type I have owned/tried to date. About $60 but IMO well worth it, clean and easy to use, and always works.
            • MNSuperAir
              • Sep 2005
              • 591
              • St Paul
              • 2016 SAN 210
              I agree with the DIM vacuum pump.
              2016 SAN 210
              2006 SANTE sold
              2001 SAN - sold
              • boatech
                • Aug 2006
                • 247
                every 100hrs if you did it at 25hr breakin 125hrs is your next tranny service
                • speck
                  • Sep 2005
                  • 236
                  are you guys talking about the vdrive unit or the tranny? i thought the new pcm vdrive was good for a "long" time
                  • Ponyh8r
                    • Mar 2006
                    • 9
                    Thanks guys, I am going to go ahead and do it a little earlier at 75 hrs, that way I don't have to worry about it for awhile.
                    • 97sport
                      • Mar 2005
                      • 78
                      • Youngstown, Ohio
                      oil and fluids are cheap maintenance items. oil change at 50 hrs. and trans. at 100 hrs. I would change it more often if you carry a larger load. i.e. ballast tank and people. this puts more strain on the trans. just like towing puts on your tow vehicle.
