Anyone know how to tighten up the lever on the Teleflex throttle control on the 1996 and up CCs? I'm not referring to the morse unit used pre-96- strictly the newer Teleflex control. I didn't even know mine was loose until I drove a brand new boat! It just has a little "jiggle" to it.
Teleflex Throttle Tightening
Tags: None
RE: Teleflex Throttle Tightening
If you put the throttle handle straight up (neutral position) there is an allen setscrew that goes up from the bottom. If this screw gets too loose, your throttle handle can fall off. Loosen the setscrew, push the handle back on, and tighten up the setscrew while holding the throttle handle in toward the gunnel. There is also a drag screw that you have to remove the upholestery to get access to.
