fireing order 351 w
  • mister.T
    • Feb 2005
    • 10
    fireing order 351 w
    hello
    can sombody tell me the fireing order for a 351 w 1982.
    thank you
    grEetZ from holland
    mr.T
  • bmh2208
    • Apr 2004
    • 288
    • 77 CC American Skier '83 2001 '03 SAN
    RE: fireing order 351 w
    There are three different firing orders for 351W engines. I had an '83 2001 with the 351. The firing order that I had was: 1-8-4-5-6-2-7-3
    It should be on the tag on the engine if it is a PCM engine.
    You can check out a thread that I helped on a while ago on wb.com. It has a few diagrams on rotor location versus disty cap orentiation.
    http://forums.wakeboarder.com/viewto...amp;highlight=
    Also check out correctcraftfan.com. They have some reference material from way back when where you can find the info.
    • mister.T
      • Feb 2005
      • 10
      thank you very much
      gr.mr.T
      • Hydrofoilmaniac
        • Apr 2006
        • 105
        • Menomonie, WI
        The firing order is listed on the engine name-plate.
        1976 Ski Nautique.....old but it\'s still going strong
