paddle wheel leak
  • disland
    • Jul 2005
    • 4
    paddle wheel leak
    My paddle wheel seal is leaking.
    Should I
    a. try and use silicon sealant on the inside?
    b. silicon sealant on the outside?
    c. Remove and reseal the whole thing?
    d. take to dealership and have them do it?
  • G-man
    • Jun 2004
    • 428
    • Allen, Texas
    RE: paddle wheel leak
    Dave while it is out of water take the wheel out from the top. It could be leaking from the o-ring on what pulls out or it could be leaking from the mount glued to the hull. If you need just an o-ring and you received the plug that goes in when the wheel is pulled just switch o-rings. I have one can give use you while you wait for a replacement. Give me call.
    Current
    2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
    Previous Fleet
    2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
    2004 Ski Nautique 206 LE Red - Black - Silver Cloud
    1993 Mastercraft Stars & Stripes 190 Red
    • Sinkoumn
      • Jun 2006
      • 578
      • MPLS - St. Paul, MN
      • Super Sport Nautique
      I'm guessing the O-ring is shot, or twisted up; either way check that first. After that I'd say just throw some non-hardening silicone along the o-ring line on the inside.
      Neuston Boards
      Nautiques
      • Rick
        • Mar 2004
        • 1250
        • San Diego, Ca
        If its leaking through the paddle wheel you can easily remove it while the boat is out of the water by pulling the pin and pulling it up into the boat. There will probably be 2 orings. PP will sell you a rebuild kit for under $10.00. Also get some waterproof grease and lightly lube the orings and twist it as you reinstall it. If you use silicone you will never be able to get it out again.
        Nautiqueless in San Diego
