speedo adjustment
  • Paniolo
    • 1
    speedo adjustment
    I have a 2000 SAN, just put a perfect pass in it and wanted to know if anyone knows how to adjust the speedo with the perfect pass speedo. I'm about 2.5 mph apart on the reading. thanks in advance.
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    The easiest way is to get a handheld gps, and adjust both to the gps. Speedos are not linear and you need to adjust them at the speed you use most. The good thing about PP is you can calibrate it for each speed. We calibrated ours on the slalom course with magnets. Enjoy the great consitant pull with PP.
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
    • Watarski
      • 65
      • Panama City Beach, FL
      I did the same thing when I unhooked all the systems earlier in the season. Took a handheld GPS and got the speedo calibrated that way. Worked perfect-
      craig
      1985 SN 2001
      • Mikeski
        • 2908
        • San Francisco, CA
        Speedo calibration
        Find a slalom course time the boat at 36 mph, it should be 16 seconds from beginning to end boat guide bouys.
