Strainer??
  • BHog
    • Dec 2006
    • 207
    • Rockwall, TX
    Strainer??
    Quick question. I have a 1999 super air and I saw a slow stead drip from the strainer (if that is what it is called). YOu think it is just a bad o ring?? I made sure it was tight. Is this something I shold worry about? WHat do I need to do to fix it
  • BHog
    • Dec 2006
    • 207
    • Rockwall, TX
    RE: Strainer??
    It has the GT40 engine if that helps
    • DRAGON88
      • 529
      • Eugene, Oregon
      • 1999 Sport Naqutique 2005 Super Air Nautique Team Edition
      RE: Strainer??
      It should not be leaking, definitely replace the o-ring, it should cost less than $1. If that's not the source of the leak then begin to examine other parts of the strainer assembly.
      How about \"Chales\"?
      RIP Nikolai (\'05 SANTE) 5/23/05 - 4/30/06
        RE: Strainer??
        Sometimes the pvc fittings that screw into the strainer body leak, take them apart, and reseal them. I use teflon tape.
        • ffmedic74
          • 835
          • Lexington, KY
          RE: Strainer??
          I would highly suggest going ahead and buying a new oring. Take off the bowl and ensure its not cracked and leaking water as well. If you get just a little bit of air around this area, it can cause the pump to loose prime. (Leading to increased temp and possible kill your impeller)
          • WakeSlayer
            • Sep 2005
            • 2069
            • Silver Creek, MN
            • 1968 Mustang
            RE: Strainer??
            I discovered that having it too tight can make it leak too. I think the Oring gets a little mashed or twisted.
            the WakeSlayer
            1968 Correct Craft Mustang
            • G-man
              • Jun 2004
              • 428
              • Allen, Texas
              RE: Strainer??
              You may try flipping over the gasket and as suggested check the fittings and the hose clamps going in and out of the strainer.
              Current
              2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
              Previous Fleet
              2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
              2004 Ski Nautique 206 LE Red - Black - Silver Cloud
              1993 Mastercraft Stars & Stripes 190 Red
