bizarre starting issue
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    This has happend off and on for a while, and I have never been able to pin it down...
    When I'm trying to start the boat, I crank on it and it cranks and cranks until I let off the key. Then as soon as I let off the key it fires right up.
    I'm pretty sure it is an ignition problem, but I have cleaned all of the ignition parts and set the gap on the points (yes it is the old style points and condenser) and this problem still comes and goes.
    Any ideas?
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    RE: bizarre starting issue
    This is just a wild guess. While cranking, the voltage at the ignition coil is pulled down to around 9 or 10 volts. That is not quite enough to fire a cold cranking engine, sometimes. When you let off the starter, the voltage jumps up, and the engine fires in the split second before it stops turning. Many ignition systems have a ballast resistor in them, and the resistor is bypassed when the engine is cranking, to keep the voltage higher at the coil.
    • skiinxs
      • 374
      • St. Louis
      • 2019 Ski Nautique 6.2 arriving soon
      My guss is that the igintions switch is bad. It doesn't send voltage to the ignition in the cranking position but it does in the "on" position. Sometimes when you release the key the engine is still spinning enough to start, sometimes it isn't. Easy to check, put a voltmeter on the ignition terminal on the switch and see if it is supplying voltage when you crank.
      Dave
      16 other Ski Nautiques
      3 MasterCrafts
      18 Ski Supreme's
      1 SlickCraft Squirt Boat
      • surroundsound64
        • Jul 2005
        • 2147
        • Longview, TX
        Re: RE: bizarre starting issue
        I have noticed it doesn't ever seem to do this with a freshly charged battery... maybe you have something there.
        2018 SAN 230
        1981 Ski Nautique
        Sold - 2000 SAN
        • surroundsound64
          • Jul 2005
          • 2147
          • Longview, TX
          Dave
          I'll check that too!!!
          Thanks for the ideas!
          2018 SAN 230
          1981 Ski Nautique
          Sold - 2000 SAN
          • richard
            • Feb 2005
            • 406
            • HK
            worth try to bypass the killswitch.
            • knowscc
              • Mar 2007
              • 18
              Install a jumper wire from the 10-32 blank post (nothing on it) on the starter relay to the coil side of the ballast resistor. This wire will allow battery voltage to power the coil in crank mode only, as this post is energized when key is turned to start position.
              • surroundsound64
                • Jul 2005
                • 2147
                • Longview, TX
                There's not a kill switch.
                2018 SAN 230
                1981 Ski Nautique
                Sold - 2000 SAN
                • knowscc
                  • Mar 2007
                  • 18
                  Do what knowscc said to do. Blank post will be marked with an 'S' for start. This post is energized when key is turned to start position, dead otherwise. Check it with your voltmeter.
                  • ken
                    • Jul 2006
                    • 23
                    • Chicago
                    I'll bet anything it's a bad battery cell or two. I had the same problem on a Goldwing motorcycle. This went on for over a year. As soon as I replaced the battery the problem instantly went away.
                    Good Luck.
                    Ken
                    Ken
                    • Andrew
                      • Aug 2005
                      • 891
                      • Tuscaloosa, AL
                      x2 makes a world of difference
                      • boatech
                        • Aug 2006
                        • 247
                        do this and all your troubles will be gone!!!!!!!!
