Alternator wiring?
  • Sinkoumn
    • Jun 2006
    • 578
    • MPLS - St. Paul, MN
    • Super Sport Nautique
    Alternator wiring?
    My last post was way too vague, so I'm starting anew. But I am just curious if I can get some feedback on the setup of this new 140amp Alternator.
    From the diagram, and a few other posts on here (Hydrofoilmaniac's post and a few others) I came up with this diagram, any suggestions/comments? From the factory they labeled the Green wire as the 'tachometer' (just in case I decided to use this alternator in another application), but I plan on not even installing the green wire when the new alternator goes in.
    So basically, I will only be using the Red post (going to the + terminal on the battery), the red wire (which is the battery sense, looped back to the red post), and the black wire (connected to the ignition). Does any of this look correct? Or am I way off?
    Mike :grin:
    [url=http://www.neustonboards.com][i][color=Blue][size=4]Neuston Boards[/size][/color][/i][/url]
    [size=4][i][color=green]Nautiques[/color][/i][/size]
  • Sinkoumn
    • Jun 2006
    • 578
    RE: Alternator wiring?
    I forgot to mention that this new alternator is going to go into a 97 Super Sport to replace the stock alternator (PCM GT-40 engine).
    • Sinkoumn
      • Jun 2006
      • 578
      Aright, how about this. Can anyone clue me into what the Brand/model alternator is in the PCM GT-40 engine? The guys as DB will be able to help me out with the install connections if I can get them the brand/model of the old alternator (is the original alternator a Mando unit?)?
      Mike
      • wake_fun
        • 1330
        • CA
        • 1995 Super Sport
        Check out my thread I just posted. I don't know if you wire it the same, but it might help you................
        Photo Album
        Ballast Install 1
        Ballast Install 2
        Amp Install
        PPass Install
        Alternator Install
        • Sinkoumn
          • Jun 2006
          • 578
          Nice, thanks much for posting that page up!
