Ongoing starting/running problem on a 1983 (2001) model
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    RE: hard start again
    Did you replace the gasket under the carb and the spacer? If not then that could be your leak. Have you pulled a spark plug to see what it looks like? Symptons like this one make you turn over each rock to find the culprit....
    Brad
    PS. your timing should be 6 degrees BTDC.
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
    • richard5150
      • Apr 2007
      • 5
      Nope, the floats were adjusted right after the carb was installed. Unless i hit the accelerator, I have never seen any gas dripping in the carb when it gets hot. It should be easy to see right?
      • Travispalma
        • May 2019
        • 1
        • Old Hickory, TN
        • 1984 Correct Craft Ski Nautique 2001(351W)
        Richard5150 did you were figure out the cause of this problem I have the exact same thing going on
