So the weather warms up yesterday and I take a day off to hit the lake. We get out there and cruise for a bit but the engine was having trouble keeping the temp at 160-180. Kept creeping up to 190 at idle. New impeller this spring and I checked for leaks.
Sadly we chose not to ski given the engine trouble and as we were working our way back to the boat ramp, she really started having trouble keeping the temps down.
I suspected that I had installed the impeller wrong or the thermostat was not working properly but was very surprised after getting her home to find the impeller was fine but the raw water pump was not pushing much water if any.
I tried a second impeller (the old one) and got the same results. Pulled the hose at idle and the water barely trickles out of the pump, gave it a quick rev and the flow did not change. Took the pump apart again and looked it over carefully but don't see anything out of ordinary.
What gives? I am at the point of ordering a new complete Sherwood pump to replace it but as an engineer, I am completely baffled as to why the current one won't work? Has anyone else every seen a random raw water pump failure like this, especially when the unit looks fine? They are not that complex of a design. I checked the lines before and after the pump for blockages, everything seems fine.
My feeling is that the pump should be pushing a good amount of water at idle and a ton when the revs are higher. Right now it pushes next to nothing and almost seems to lose prime if it has to pull water up from waterline.
Thanks in advance,
Lorin
Thanks in advance,
Lorin
