What brand/model ballast pumps is CC using on the new boats and are they still using a separate pump for fill and discharge or one pump for each tank that is reversible?
RE: 2007 CC Ballast Pumps
They are using Jabsco Water Puppy pumps. One pump for each tank that is reversible.
Nope. The new pumps don't require seperate valves. I'm sure there are petcocks that close off the thru-hull fittings in an emergency, but for day-to-day use, there are no valves.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Does anyone have the problem of the pumps tripping the circuit - I have a 2006 210 - believe the first year of the new pumps2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
I'm sure there is a service bulletin about this. Check with your dealer.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
The new pump systems are really not designed to be filled while under way. They do not use a scoop style pickup so that they can drain while under way. If you look at the thru hull it is flat against the hull with a small screen. While under way you have turbulence that keeps it from filling fast. The idea is to put the boat in, go to where you ride and stop. Then turn on pumps while your rider is getting the rope attached, board on, and jacket on the tanks will be full. Since they are flat on the way back to the ramp or dock they will drain out. I just ordered these thru hulls to start a ballast system on my boat and my dealer explained this to me. I have been researching this for a while as I want to do it once. Makes sense to me anyway.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
The impeller is easy to change, remove the cap, swap impeller and replace the cap. If my memory is correct, the yellow impellers were bad, and they will replace at no charge from the mfg.
I have a post somewhere about my ballast install last year. I used thru hulls out the back under the deck for mine.the WakeSlayer
1968 Correct Craft Mustang
Re: RE: 2007 CC Ballast Pumps
Originally posted by bchesleyThe new pump systems are really not designed to be filled while under way. They do not use a scoop style pickup so that they can drain while under way. If you look at the thru hull it is flat against the hull with a small screen. While under way you have turbulence that keeps it from filling fast. The idea is to put the boat in, go to where you ride and stop. Then turn on pumps while your rider is getting the rope attached, board on, and jacket on the tanks will be full. Since they are flat on the way back to the ramp or dock they will drain out. I just ordered these thru hulls to start a ballast system on my boat and my dealer explained this to me. I have been researching this for a while as I want to do it once. Makes sense to me anyway.
I read a post on here that said that was a common problem due to a bad pump impeller. I am going to change the impeller and hope that the change prevents the tank from filling on it's own.
Thanks for all of the help! This forum rocks!!2007 Air Nautique 211
