Lifter Ticking
  • 1998CanadaNautique
    • Jun 2006
    • 43
    Lifter Ticking
    I fired up my 1998 Nautique GT-40, after being in winter storage and a lifter is ticking. It wasn't doing this when I winterized it. All I did was change the oil and winterize. Any suggestions?
    Thank You
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    RE: Lifter Ticking
    Run it. Let the oil warm up and flow good through everything. Sometimes that'll help.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
      • Jun 2006
      • 43
      RE: Lifter Ticking
      How long should I let it run for?
      • surroundsound64
        • Jul 2005
        • 2147
        • Longview, TX
        RE: Lifter Ticking
        Until everything gets to operating temperature... I'd probably start it up and let it warm up a little then just go for a 5-10 minute cruise around the lake.
        If that doesn't help you might poor some marvel mystery oil in your crank case and let it try to do its thing.
        2018 SAN 230
        1981 Ski Nautique
        Sold - 2000 SAN
          • Jun 2006
          • 43
          RE: Lifter Ticking
          I've ran it for 10mins in the driveway. Where do you put the Marverl oil in?
          • bchesley
            • Feb 2006
            • 1252
            • Tyler, Texas
            RE: Lifter Ticking
            You need to drive it. Running it in the drive way adds no load. It will get warmer on the lake. Add the Marvel to the crankcase...
            Brad
            2001 Super Air Nautique
            Python Powered
            100 Amp Alternator
            Dual Batteries
            Many upgrades coming...
              • Jun 2006
              • 43
              RE: Lifter Ticking
              A dumb question, but i'm new to this. Where is the crank case? Do Ijust add it with the regular oil?
              • Rick
                • Mar 2004
                • 1250
                • San Diego, Ca
                RE: Lifter Ticking
                Just add it as per directions on the can. It goes into the regular oil filler. Your lifter is hydraulic and has just collapsed. I agree you should run it on the lake and try to see if that works. Then try the Marvel Mystry oil.
                Nautiqueless in San Diego
