Window frame rubber(gasket)?
  • onenautiqueone
    • Feb 2025
    • 89
    • Nor Cal
    I just powdercoated the window frames and need to get new rubber gaskets-moulding. The sun had did some damage to the old ones. Anyone know where I might be able find these?
  • Revman
    • Aug 2005
    • 19
    RE: Window frame rubber(gasket)?
    The rubber strips on my boat were all cracked so I just flipped them over and they look like new. I think you might be able to use regular black weather striping if you can find the right size.
    • mfloski
      • Jan 2005
      • 166
      • Longview, TX
      I purchased new from www.mcmaster.com, it wasn't exaclty the same but so close that it didn't matter.
      \'99 Sport Nautique, and darn proud of it!
      • TRBenj
        • 1681
        • NWCT
        Re: Window frame rubber(gasket)?
        Are you talking about the gasket between the glass and the frame, or the gasket between the frame and the deck?
        1990 Ski Nautique
        NWCT
        • onenautiqueone
          • Feb 2025
          • 89
          • Nor Cal
          • Miljack
            • Dec 2004
            • 1616
            • Charlotte, NC
            • '08 230 TE ZR6
            You'll need to order from the dealer. I ordered the gasket between the bottom of the frame and the deck, and the dealer ordered the gasket for the windshield, so I know you can still get them. I do think that the older versions are a little different from the new windshields, so ask.
            Jack
            2008 230 TE-ZR6
