I can't seem to get the carb tuned right. I have the Holley 4160 and I recently rebuilt it. I followed all of the instructions and whatnot and I still have a problem. It will accelerate just fine with no hesitations and it runs strong with good fuel delivery. Once it drops down below 1k rpm it bogs down and dies. I have all new gaskets for absolutely everything and the PCV valve is still good with a new hose running from it to the carb, so it shouldn't have a vacuum leak. The floats in the bowls have been measured to their correct positions and the fuel is doing what it is supposed to from what I can see. This has given me a problem for quite some time now and I'm about to break down and just go get a new carb out of sheer frustration. Anyone know what I need to do?
Did you set your metering block correctly? For that carb and your altitude the screws on the metering block should be approx 2 1/2 turns OUT from seated.
This may be a dumb question but I'll ask anyway... did you get all the parts back in it? That carb has a bowl transfer tube that when left out will still allow the engine to run, but as you describe, not idle. I think it's the 4160 that will do that anyway... I quickly looked online for a schematic of it but couldn't find anything.2018 SAN 230
1981 Ski Nautique
Sold - 2011 Sport 200V
Sold - 2000 SAN
2 1/2? I've never tried that before, I've always heard 1 1/2 and that has always worked out well for me in the past.
I'm pretty sure the carb is 100% back together, I went back in and took it apart just to put it back together to make sure everything was there.1996 Sport Nautique w/ EFI GT-40
