Perfect Pass paddle wheel SAN 210 2006
  • Laptom
    • Oct 2003
    • 876
    • Eindhoven, Netherlands
    Where is the Perfect Pass paddle wheel located in a 2006 210 Team? Our 210 doesn't get any mph on the Perfect Pass as not on the Speedo. So I think the Paddle wheel is dirty or broken. The boat is still in the slip so I cannot crawl under it, I will have to access it from the inside.
    Thanks Tom
  • Laptom
    • Oct 2003
    • 876
    RE: Perfect Pass paddle wheel SAN 210 2006
    Nevermind. I found the spot. It's on the port side of the transmission and it easy accessible by removing the center cushion and the cooler. You can pick it out while the boat is in the water and put in the trailer dummie from Perfect Pass. Works great!!
