I installed a second batt. on my 84 nautique. after installing the switch i can't seem to get the boat to run or anything for that matter in position 1 but it works fine in 2 and all. please help!
RE: batt. switch problems
I took the wire coming from the starter relay and connected it to the common on switch, then took the pos. from batt. 1 and connected it to #1 post on switch, then took the pos. from batt. 2 and connected it to the #2 post on switch. For the ground i used a jumper from batt. 1 to batt. 2 ground
Well, it definitely looks like you have it wired correctly. Given that it works fine on #2 and ALL, I would just re-check your connections at the switch and battery for #1. Hopefully I'm not insulting you when I ask if the #1 battery has a charge? If there are no problems there, you might just have a faulty switch.2001 Air Nautique
at the time of installation i put 2 new batts. in , when it didn't work i put a new relay in and took the first switch back to woody at south east correct craft in orlando and got a new switch and had it tested. connections are solid. and i am not insulted at all i have been asking myself the same basic ?'s over and over again. I am stumped. any thing else i can try?
