Strange starting problem???
  • Thesnowman
    • Mar 2007
    • 22
    • Texas
    Sometimes when I am out on the lake and have the engine turned off and I go to crank the engine the engine will not turn over. Its almost as if the ignition is not getting any power either from the ignition to the starter or from battery to ignition. I can either turn on and off the master kill switch or just wait a few minutes and it will crank right up like nothing is wrong at all. Its not become a problem because it will always crank right up if I am willing to be patient but I would like to eliminate this problem if at all possible in the future.
    Any suggestions on things to check?
    And the battery is well charged if thats a suggestion...
  • MarkP
    • Sep 2003
    • 155
    • Rochester Pennsylvania
    RE: Strange starting problem???
    I had the exact problem it turned out to be a bad starter had it replaced under warranty never happened again!
    2004 Ski 206 Limited,Midnight Blue and Black,
    Silver Accents,330 Excalibur,Perfect Pass.
    Nautiques Rock!! My 2004 206
    • TRBenj
      • 1681
      • NWCT
      Sounds like a neutral safety switch problem, most likely due to a maladjusted transmission cable.
      1990 Ski Nautique
      NWCT
      • Fonseca
        • Apr 2006
        • 35
        • Portugal - Castelo de Bode
        try to shake de thorthle lever (transmission lever) without jump of the neutral position (don't push up de security ring) allways with your finger pressing the start. If the engine cranks intermitent it means that you have a proble with your neutral switch.
        I have exactly the same problem in my SANTE 210. What i did? whell, is not the best way to fix it, but i did a by pass in the neutral switch, connecting both terminals toghether. The good new: it starts allways. The bad new: it starts even with forward or reverse engaged. If you do that, be very carefull when starting the engine, You have to be sure that you have the lever in neutral position.
        Good luck!
        • boatech
          • Aug 2006
          • 247
          Re: RE: Strange starting problem???
          Good luck!
          this is you fix right here he knows what he speaks cant tell you how many boats come in with this problem!
