Glovebox Hinge
  • dyoungman1
    • May 2006
    • 45
    Glovebox Hinge
    Can someone tell me if the small hinge on the dashboard cooler/glovebox is suppose to hold the lid open? I think mine needs replacing because as soon as you let go of the lid slams down.
    Does anyone know where to get these?
    Thanks,
    Dave
    1998 SKI NAUTIQUE - GT40
  • MikeC
    • Apr 2007
    • 535
    • Georgia
    • 1999 Ski Nautique (Python powered) 2017 GS22 (sold) 2005 SV211 (sold)
    RE: Glovebox Hinge
    Are you talking about the hinge or the gas strut that holds the lid open? You can find the gas strut at white lake marine http://www.whitelake.com/catalog/cc_...2_products.htm
    It takes about two minutes to replace.
    • dyoungman1
      • May 2006
      • 45
      Yes the gas strut.
      Thanks,
      • MikeC
        • Apr 2007
        • 535
        • Georgia
        Bad link on the first one, here's a link that should work; http://www.shopwhitelake.com/glboxgassh.html
        Be sure to use the PN discount, "PND" in the coupon code box right after you add it to the cart.
        • dyoungman1
          • May 2006
          • 45
          I just ordered one through them. Thanks for the info.
          • SoCalNautique
            • Aug 2006
            • 22
            • Ontario, CA 91761
            I bought mine at the local Correct Craft dealer and they always have them in stock. I guess they go out periodically. Cost was about $16 (California Correct Craft give a 10% discount for PN members). FYI. I just read my old, worn out gas-filled strut and made sure it had the same or better psi rating to make sure it would hold it up. Easy replacement with two small C-Rings.
            Chris
            • benwa43
              • Aug 2004
              • 19
              • South Carolina
              Napa also has them
