Anyone have any suggestions for releasing what appears to be a stuck starboard ballast valve. Knob at helm won't turn.
RE: Ballast control knob at the helm won
Probally a kink in the control cable. I had to replace mine. And yes, I broke the knob trying to make it work. Sounds like you have a warranty but if not:
https://www.flow-rite.com/store/mari...oreretail.html
I broke mine too trying to turn it. Like phbrown said, check the cable and valve at the rear first.....
I replaced the flow-wrongs with the T-H valves already. I even re-installed the T-H valves after WCCC installed them trying to get them to work easier.
My next boat modification will be replacement of the fill pumps with impeller pumps and elimination of the PITA valves.
I had a knob break on my 03 and I replaced with one of the valves listed in the post I'm linking to.
http://www.planetnautique.com/index....t=ballast+knob
I made the mistake of buying my replacement valve from the dealer before I knew about Flow-Rite's website and got charge twice as much for the same thing.
Chad
Just had my valves replaced. It is a recall and covered as such. There is a service bulletin here somewhere. No need for warranty.2012 200
2008 196 TE
2004 211 LE
