New ballast drain pump needed
  • Chad52
    • May 2004
    • 295
    • Huntsville, AL
    • 2008 Super Air Nautique 210 2003 Super Air Nautique Team 210 2001 Super Air Nautique Team 210 1999 Super Air Nautique 210 1994 Mastercraft Prostar 190 1992 Manta Ray 189 Sport
    So my port drain pump died. What a PITA to replace, you have to take the tank out to get to it. Anyway, it's just a pretty standard Rule 1100 pump, but I can't find it local anywhere. Anybody replaced one before or have any suggestions on where to get a replacement cheap and fast?
  • bmh2208
    • 288
    • Austin
    • 77 CC American Skier '83 2001 '03 SAN
    RE: New ballast drain pump needed
    I think I got a replacement a local west marine. And yeah....taking those tanks our is a huge pain. I think the hardest thing is getting the hoses off.
    • Flux
      • 408
      • Palmdale, Ca.
      http://www.livebaitlarry.com
      He's got em, not sure how fast though.
      You could take the tank level sender out and drain it through that hole with a suitable pump. Not an easy task by any means. If it's out of the water, remove the drain hose to the hull and stick it into the bilge and let it go out through the drain. Might get a little wet in the hull though.
      Another reason to rip out the tanks and replace with fat sacks. I keep an extra rule pump on board too.
      • Chad52
        • May 2004
        • 295
        • Huntsville, AL
        Anybody know off the top of your head what the exact part number is for thr Rule pump? I've gotta order one online. There's no part number listed on mine....
        Chad
        • Flux
          • 408
          • Palmdale, Ca.
          1100 GPH Dual port Rule. The second port has a stopper in it. Direct replacement.
          • Chad52
            • May 2004
            • 295
            • Huntsville, AL
            Any idea why they use a dual port and plug one hole? Sounds like you could just as easily just use a single port...
            Chad
