351W on '82 Ski Supreme Help
  • smiley11
    • May 2007
    • 10
    I have just bought an 82 ski supreme with a 351 windsor. We have got it running, just rebuilt the carb (holley 4160 marine), and now it is backfiring. It idles well, but won't run over about 10 mph. The 4 barrels won't open up all the way. Is this a vacume problem somewhere? Timing? Any ideas...Please help if you have any idea. I really appreciate it..
    thanks
    \'82 Ski Supreme
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    RE: 351W on
    will it rev up w/ the prop disengaged?
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • smiley11
      • May 2007
      • 10
      It will rev up and begin to backfire and sputter when the prop is disengaged. Also the gear switch blocks it from reaching too many rpms while not in gear.
      \'82 Ski Supreme
      • Andrew
        • Aug 2005
        • 891
        • Tuscaloosa, AL
        i've had similar symptoms with a bad battery, but i doubt thats ur problem....
        • Fast351
          • Oct 2006
          • 315
          • Winsted, MN
          • 2001 Ski Nautique
          Check time first. Backfire is almost always an ignition problem. It could be a REALLY bad lean condition, but you'd have to screw something up pretty badly in the carb for it to be that.
          2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
          • pj
            • Oct 2003
            • 323
            • Rochester, MN
            • 1991 SN 1996 SN
            ya, if the carb just got rebuilt, i'd take a look at the timing too. sounds like the likely culprit. DOUBLE AND TRIPLE CHECK your spark plug wires that they are going to the correct cylinders for your firing order. especially if you have a pro-tec system. (speaking from experience here and a much thinner wallet)
            Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
            • wristy_j
              • Jun 2007
              • 4
              I'm no mechanic, but I had a very similar problem that I was able to fix with some help. There's a vaccuum actuated rubber gasket that opens the second two barrels that will allow you to rev up and get to the high end. It's a flat disk looking thing with a metal wire sticking out of the bottom, mounted to the side of the carb body. Take that disk-like cover off and look at the vaccuum diaphragm inside (I think we actually had to detach the whole assembly from the carb body first). There's the main diaphragm, and then a separate little hole for the pressure to get in/out. I had my carb rebuilt by an incompetent mechanic, and he put a screw right through the ring gasket around that little hole, and left it that way. We taped it up with some electrical tape, re-cut the hole for the airway, put it back together, and voila - we were hauling *** all over the lake! Hope that helps!
              J
              • wristy_j
                • Jun 2007
                • 4
                "Metal wire" was probably a bad choice of words. It's more of a thin, solid, metal rod.
