Perfect Pass not working???
  • awmclaug
    • May 2007
    • 11
    Hey, Please leave comment if you have any information! Thanks!
    The perfect pass on my SANTE 03 is not working the gauges and everything work fine and say its on... but it's almost like its not connected to the engine because it won't kick on to maintain the speed...
    Please provide feedback of what I might can do to fix this!
    Thanks!!!
  • pj
    • Oct 2003
    • 323
    • Rochester, MN
    • 1991 SN 1996 SN
    RE: Perfect Pass not working???
    Look at the servo motor and make sure the two wire plugs are plugged in to the wires running back to the master module. If these are unplugged, the perfect pass will seem like it is on and working but the servo motor will not actually do anything to control the speed.
    Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
    • MNSuperAir
      • Sep 2005
      • 591
      • St Paul
      • 2016 SAN 210
      I have this same problem. My PP beeps like it wants to take over speed control but it doesn't. just started this weekend. Any other ideas? The 2 connectors going to the servo are hooked up.
      2016 SAN 210
      2006 SANTE sold
      2001 SAN - sold
      1991 Sport Nautique - sold
      • bmh2208
        • 288
        • Austin
        • 77 CC American Skier '83 2001 '03 SAN
        Your stepper motor might be bad. When we bought our used 03, that was what was wrong. If you take the motor out and it is seized, then it is probably toast. You can probably test it by taking off the knob on the top, and then turning the boat on (don't start it). It should make noise and center itself. If it looks like it's trying to turn but doesn't, then it is probably bad.
        • MNSuperAir
          • Sep 2005
          • 591
          • St Paul
          • 2016 SAN 210
          Must be what is wrong, I was trying to turn it manually to see if everything seemed fine snd it is siezed up. Was the new part expensive? Where is it the cheapest? (SKIDIM?)
          2016 SAN 210
          2006 SANTE sold
          2001 SAN - sold
          • bmh2208
            • 288
            • Austin
            I was able to get the armature part out of the motor casing, but it was split in half. I actually tried to glue the two pieces back together, but the spacing was slightly off and it didn't work very well.
            The best place is to call perfect pass. I think when I called it was a little over 100 bucks for the motor, including the cable.
            Don't remove the old one before the new one comes in if you want to go out on the boat. It actually holds tension on the throttle cable and the engine won't rev if it is disconnected.
