Fuel Pump relay
  • go46
    • Aug 2003
    • 44
    Fuel Pump relay
    Anyone have a part # for the 2 relays on the GT-40? I have the hella relays, but am not having any luck finding them, or cross- matching them. I have seen where some people have swapped over to bosch (sp?) relays.
    Thanks.
  • skinautique
    • 1749
    • Colorado
    Don't have the numbers but I would call any Nautique dealership and they can take care of you with no problem. Was the fuel pump relays your problem or is there more?
    • go46
      • Aug 2003
      • 44
      Just looking to save some coin. I think one of the relays is the problem. Just wish there was an easy way to test the relay.
      • skinautique
        • 1749
        • Colorado
        wiggle it while the boat is running. If it shuts off, more than likely, there is a problem with it.
        • ag4ever
          • 1180
          I want to know where to get the relays and the waterproof sockets for some other projects. I checked and checked, and still have not found them.
          I think they are made by the mega conglomerate TYCO.
          • legmaker
            • Sep 2003
            • 4
            You can get those apart and clean the conacts. I had a problem with this and my boat would not run. Took them apart and took an emory board and sanded the contact points. no problems since.
            • go46
              • Aug 2003
              • 44
              Does everyone but me know that if the emergency cut-off switch is bad the fuel pump will not work?? I am hoping this was my problem, and it only took me 7 hours to figure it out. It seems that my intermittent fuel pump was caused by a faulty/ bad connection inside the switch. I need to do some more testing but I am 95% confident I have found my problem.
