Rubber Glue?
  • frymantcu
    • Jun 2005
    • 31
    • DFW
    Rubber Glue?
    The rubber 'weather striping' around the bottom of the engine hump on my DD has come off and I was wondering if anyone knew a good adhesive that will hold and not eat into the plastic? Thanks
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Rubber Glue?
    Use a hot glue gun.
    Nautiqueless in San Diego
    • igkya
      • Oct 2003
      • 227
      • Minden, NV
      • Club boat 2005 196
      RE: Rubber Glue?
      Anyone try Gorilla Glue?
      • Andrew
        • Aug 2005
        • 891
        • Tuscaloosa, AL
        RE: Rubber Glue?
        automotive weather stripping adhesive u can find it at ur local autozone or parts house
        • skijones
          • Mar 2005
          • 235
          • COLUMBUS OH
          • 1985 2001 1999 Snob
          RE: Rubber Glue?
          If you use auto weather stripping adhesive, be carefull. This stuff is also referred to as "Yellow Death" because it will stick to anything and is **** near impossible to get off. Put a small amount in the channel of the plastic and let it set up for 5-10 min. I would recomend pulling the engine doghouse completely out of the boat, to avoid getting glue on everything.
          Hot glue might work, but I would be concerned that it would remelt on a real hot day. Gorilla glue is great, but it expands and would probably attract dirt.
          PS, get a buddy to help with the engine cover. They are not real heavy, but they bounce real good when you drop them out of the boat. Unfortunately, I speak from experience.
          • Andrew
            • Aug 2005
            • 891
            • Tuscaloosa, AL
            RE: Rubber Glue?
            i used the black weatherstripping glue..... still a little messy/sticky though
            • ag4ever
              • Feb 2004
              • 1180
              RE: Rubber Glue?
              If it is hot enough to remelt hot glue, then I don't think I want to be out in that weather.
              • skijones
                • Mar 2005
                • 235
                • COLUMBUS OH
                RE: Rubber Glue?
                Ever sit on a vynal seat after it sat in the sun for a coupel hours?
                • skijones
                  • Mar 2005
                  • 235
                  • COLUMBUS OH
                  RE: Rubber Glue?
                  Sorry, guess I cannot spell anymore.
