Slop in steering wheel
  • go46
    • Aug 2003
    • 44
    Sorry for all the posts lately. Just trying to make my tired '97 a new '04 ;-). I can grab my steering wheel and move it back and forth (in and out I guess) quite a bit. I am sure this is not normal. The piece behind the wheel that the wheel is screwed onto moves the same. I assume it is a problem inside near the tilt mechanism. Any ideas on how to take the slop out?
    Thanks.
  • skinautique
    • 1749
    • Colorado
    Is the main nut for it tightened up? It is located behind the center pop out cap.
    • go46
      • Aug 2003
      • 44
      Yes, first thing I checked.
      • skinautique
        • 1749
        • Colorado
        Is it slop while you are driving it or slop while you are putting your hands on the wheel and just moving it up and down?
        • go46
          • Aug 2003
          • 44
          Slop is noticeable when sitting in the driveway- not while driving. The top and bottom move back and forth.
          • skinautique
            • 1749
            • Colorado
            The bushings could be worn out so there is some slop in there. All of that stuff is located in the helm. I would check with your dealer but more than likely, you would need to replace the helm.
