351 Carb Idle stall problem
  • mfloski
    • Jan 2005
    • 166
    • Longview, TX
    Have the PCM 351 Carborated engine, it has a new carborator as of about 40-50hrs ago, new spark plugs, good gas, etc....it runs fine except when you are just barley in drive or reverse, it stalls. If in neutral it is fine, but if you just click in to drive and idle along it will stall....give it a little more gas and it runs fine.
    Any help would be great. Thanks,
    \'99 Sport Nautique, and darn proud of it!
  • MiracleDriver
    • Apr 2006
    • 120
    • Ontario, Canada
    Re: 351 Carb Idle stall problem
    timing!!!
    are you running electronic ignition or points?
    how old is the motor? what boat, model?
    whoever installed the carb have them check it, but I am willing to bet your timing is off, buy a tune up kit if applicable. rotor, condensor, points and cap.
    as the motor's get old condensation builds up and rises up through the distributor. this can fry electronic parts and ruin the seal you have around the cap and distributor.
