Problems with Electric Motor on '93 BFN Sun Deck
  • Tomfooter
    • Mar 2004
    • 134
    • Dublin, VA
    Has Any one had problems with the electric motor that raises the sun deck / motor cover on a '93 Barefoot Nautique or Nautique Excel? The cover will not raise by itself (most of the time) unless you assist it with your hand (it will go down great! :shock: ). It's as if the motor is just not powerfull enough to lift the load. I have had the motor checked, installed larger gauge wiring, and even installed a new 900 CCA Gel battery, and nothing seems to help. :x (Sometimes, while under power, it will very slowley raise the cover, but not always.) Does anyone have a cure?
    Tomfooter
    \"You could by a cheaper boat, but then you would have to ride it.\"
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Problems with Electric Motor on
    How about lubricating the runners/ screw. Any grease that old must be really dirty/sticky.
    Nautiqueless in San Diego
    • Tomfooter
      • Mar 2004
      • 134
      • Dublin, VA
      How do you access the runner or screw mechanism inside of the shaft? It looks like a sealed unit to me, but I would like to give it a shot. :???: I've tried everything else that I can think of. Anyone have any diagrams or pictures?
      Tomfooter
      • Tomfooter
        • Mar 2004
        • 134
        • Dublin, VA
        I can't believe no one else has had this problem.......
        Tomfooter
        • Tomfooter
          • Mar 2004
          • 134
          • Dublin, VA
          Fixed IT! Bad crimp in the two red power leads going to the toggle switch. Not letting enought "Juice" flow! Works like a champ now. Yellow_Flash_Colorz:
          Tomfooter
          • WakeSlayer
            • Sep 2005
            • 2069
            • Silver Creek, MN
            • 1968 Mustang
            I had this exact problem in my 92. I never did get it sorted out. I just started the boat to raise it, and it was a little quicker that way. Wish I would have looked at it further. I had another issue with it in that it got bound up in the lowered position once. My brother ripped it apart and, as I remember, had got wound down so tight it jumped part of a thread and seized.
            While that thing does have a huge lid compared to the newer SAN's I think the new jack screws have way more power to through them.
            the WakeSlayer
            1968 Correct Craft Mustang
