I have a 2002 210 and I've noticed that when I turn right my indicated speed on PP drops much lower than my regular speedometer and PP tries to compensate and I end up going way too fast. When turning left everything is fine, both gauges read pretty close and the boat maintains speed properly. The paddle wheel is on the right side of the boat so I'm confused why it reads slower when I turn right. PP operates great in a straight line. Any ideas? Is this just a normal thing?
RE: Perfect Pass doesn
This is a random guess. Is you paddle wheel located on the left side of the boat? If it is, it might be in turbulent water when turning to the right, because the left side of the boat is higher, or the paddle wheel might get in turbulence from the fins on the bottom of the boat, or both might be happening.
- Jul 2003
- 529
- Eugene, Oregon
- 1999 Sport Naqutique 2005 Super Air Nautique Team Edition
This is a known problem. One of the ballast thru hull strainers is right in front of the pp paddle wheel and has been known to throw the PP off. Might be something else, but I'd definitely check into that.How about \"Chales\"?
RIP Nikolai (\'05 SANTE) 5/23/05 - 4/30/06
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
There was a service bulletin to change the thru-hull pickups from the scoop style to the flat style to get rid of this issue.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
