Noise coming from GT-40
  • jedgell
    • 170
    • Bozeman, MT
    • 2004 SN 196
    Last week the engine in my boat started to make a high pitched whining noise. Its not loud, but you can definately hear it. It makes the same sound as the fuel pump from early to mid 90's Chevy trucks. Could it be the fuel pump in the boat? It just started last weekend, and the boat ran fine. It only makes the noise when the engine is running. I checked it with the ignition on, but the engine shut down, and it didn't make a sound. Any advise? Do I need to worry about this?
    Thanks for the advise.
    \'95 SN Signature Ed.
    GT-40
    PP Stargaze
    **For Sale**
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    Could it be the impellor? Was it changed this season?
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
    • gotwake
      • 304
      • Mundelein, Il
      Was the boat in the water at the time? Or were you running it with a hose? In gear and in neutral did it make the noise? A little more info might be helpful - which engine?
      The person who said \"Money can\'t buy happiness\" never rode behind an \"OLD\" 210.
      • M3Fan
        • 1034
        if it is a squirrell-sounding noise (for lack of a better term) it could also be the trans fluid pump. Does it go away if you give it a tad more throttle?
        2000 Ski Nautique GT-40
        2016 SN 200 H5
        www.Fifteenoff.com
        • jedgell
          • 170
          • Bozeman, MT
          • 2004 SN 196
          gotwake,
          The boat was in the water at the time it made the noise, it did it in neutral and in gear. I had been at the lake all day, it just started doing it just before I left. I couldn't tell if it make the noise at higher speeds. Its the GT-40 engine. I replaced the impeller last month.
          GT-40
          PP Stargaze
          **For Sale**
          • skinautique
            • 1749
            • Colorado
            More than likely it is one of your fuel pumps. Have you been running gas with alcohol?
            • nms1991
              • 477
              I would also suspect it was one of the fuel pumps or a restriction in the fuel system. But check what type of gasoline you are running to make shure it is not alcohol blended, it should be marked on the gas pump
              • jedgell
                • 170
                • Bozeman, MT
                • 2004 SN 196
                Thanks for the help, I took the boat out last night and it didn't make the noise. Hopefully it won't come back. As far as I know there isn't any alcohol in the gas, but I'll check next time I fill up.
                GT-40
                PP Stargaze
                **For Sale**
                • tryan
                  • Nov 2003
                  • 267
                  • gatlinburg tn
                  you might take a look at your belts. any mis-alignment or water on the belt might cause a squeal under load.
                  belt squeal would be more apt to happen when you first start the boat with the thermostat closed and the alt. kicking in to overcove the start cycle discharge.
                  red right return
