need check valves for ballast
  • Batman
    • Jan 2005
    • 186
    • Kingsport, TN
    Just installed an auto ballast, but water back siphons, so anybody know where to get check valves to stop this? I need three.
    If you don\'t do it today, you will be one day older when you do!!
  • Andrew
    • Aug 2005
    • 891
    • Tuscaloosa, AL
    RE: need check valves for ballast
    home depot, lowes, someplace like that
    • goodfoot00
      • 39
      • Noblesville, Indiana
      I used flapper style check valves for landscaping sprinkler systems at Lowes, they are not the greatest and you have to mount them vertically, but they do the job.
      1995 Super Sport, GT40 with EFI
      NDT Tower, plumbed ballast, PP
      • Gizmo
        • Jun 2006
        • 54
        • Grapevine Texas
        I used some brass check valves from Lowes for about $15. They are near the water pumps and filters. They have spring inside that will need to be cut. You can unscrew the nut, take the spring and cut it in half. This reduces the pressure needed to open the valve. Its worked great for me.
