Boatmate trailer brake problem...
  • AirJeff
    • Jul 2004
    • 168
    • White Bear Lake, MN
    It was mentioned before, but make sure the reverse wire is working on your conector. We had problems before because a connection came loose. Once that was fixed reverse lockout worked fine.
    Jeff
    2002 Air Nautique (DD)
    GT-40
    • thedude
      • Apr 2007
      • 451
      • SW PA
      Well, as was mentioned earlier, I wasn't getting power from the truck to the blue reverse wire on the trailer (determined with a meter). Turns out my truck connector was a bit corroded. Replaced the truck 6 pin connection and converted the trailer to a matching 6 pin circular connector instead of the strait 5 connector. Everything works great now. Thanks for everyone's input.
      Matt
