Electrical Problems '85 SN
  • nautique99
    • 6
    Just got the boat in the water this weekend and am having some electrical problems with the gauges. After running for about 15 minutes all the gauges were pinned to the extreme right, past where you could see them.
    When I shut the boat off for about 2-3 minutes and restarted the engine they acted normally for about 10 minutes and then were pinned again. I assume there is a short somewhere, but don't know how to attack the problem.
    Also, the blower doesn't seem to be working, but was when I started the boat in the driveway last weekend. Not sure if this is the source of the problem.
    Appreciate any help on this...
  • darrel409
    • Jul 2004
    • 566
    • San Dimas, So. Cal
    RE: Electrical Problems
    Its usually a grounding issue. Follow your ground leads and make sure they are clean and tight.
    Good luck
