I lost the prop on My 2001 Super air 210 team edition. I dont know what specs to order. I need to know the specs of the factory prop. PLEASE HELP!!!!!!!!!
Tags: None
I just want to know how you "lost" your prop.
You can get your hands on an Acme 644 or 856. 644 is good and we run about 1600 lbs ballast total. I do wish I had the 856 though, better hole shot I have heard, but you will lose a bit of top end, which I don't care about that much.
I recommend both the 644 and the 856. I have both. The 644 is good if you don't run huge amounts of ballast (1000# or less) and the 856 is great for a good hole shot while running 2000# or more ballast. One problem is the 856 tops out at 33mph at 4200 rpm's in my SAN. Only a problem if you cruise alot, but we mainly board.2016 SAN 210
2006 SANTE sold
2001 SAN - sold
1991 Sport Nautique - sold
