Faria Speedo Wiring
  • ripfish
    • Sep 2003
    • 14
    • Chico, CA
    Faria Speedo Wiring
    I would be interested in the instructions recieved on wiring up the Faria Speedo when replacing a teleflex gauge. This is on a 02 196.
    The instructions I recieved had nothing regarding the PP harness or the remaining wires.
    Here is what I have done so far and the result.
    Wire Tach and appears to work.
    Speedo Wiring.
    Potentiameter prewired on from WCCC.
    PP Harness
    Small Green wire to Sensor
    Small White wire to GND
    WCCC told me that's where those were to be wired
    Purple Wire to Bat
    Black Wire to GND
    Blue Wire to Spaded Backlight
    When I key on the boat, the speedo slowly goes all the way past 50 mph and then stops. Takes about 40 seconds for this to happen. Doesnt seem right.
    Thanks for your help.
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Faria Speedo Wiring
    I just had Jeff post the instructions I received in the Downloads section Take a look. Also I did a writeup with pictures a while ago Search Faria.
    Nautiqueless in San Diego
